Report Export Photos not Showing
2234
08-16-2021 02:59 PM
EddyClark
I cannot get attachments to export in Report, even though they appear in the Preview.  Screenshots are from the generic templates generated by S123.  This is true for all attachments - in parent table and repeat table - not just the example I've shown below.
EddyClark
Add this to the end of your doc.
${#$attachment}
${$file | size:350:0}
${/$attachment}
EddyClark
Just found this, which is my problem:
  • The inclusion of any type of feature service attachments (photo, signature, annotated images…) is not supported when your data is hosted in ArcGIS Enterprise.
https://www.esri.com/arcgis-blog/products/survey123/announcements/introducing-survey123-feature-repo...
LeonardBarnhill
I am stunned that this is still the case.  The referenced document by EddyClark was a 2019 document.  I appreciate EddyClark for finding it but I sincerely hope someone from ESRI will step in and reference a newer document that updates this information or addresses this inability to create reports that include attachments when working from our own Enterprise server.
ShariForbes
I am having the exact same issue. The signature is being used in a legal document and therefore must show; otherwise we wouldn't even use Survey123 as our solution.
EddyClark
${#$attachment}
${/$attachment}
ShariForbes
THANK YOU!!! I've been messing with this for hours. Can I give you more than one kudos?
I only had this but you gave me the answer to the most important piece of the puzzle.
${#$attachment}
${$file|getValue:"name"}
Thank you so much for your response.
