Repeats with "minimal" appearance doen't work into a group with field-list appearence for Webform
1340
08-09-2022 10:22 AM
HaroldHerrera1
Hello all,
In my Survey I have a group with the appearance "Field List", which contains several repetitions with the appearance "minimal", so that it starts without record, as the following text says:
The app works fine.
However, in the web form, the repeats "create" the first record empty, as no appearance was chosen. Inside these repetitions, some questions must be required, only if the record is completed. To continue to the next page, I must to erase the empty records in the repeats.
How I can set to use the "minimal" appearance and avoid creating initial records in the web form?
@IsmaelChivite
HaroldHerrera1
The behavior is present when the draft mode is on.
BarbaraWebster1
Hi @HaroldHerrera1,
I just tested applying a minimal appearance to a repeat, and it looks like it is functioning as expected in the web app and not creating the first record automatically.
Would you be able to share your XLSForm so we can look into it in more detail?
-Barbara
HaroldHerrera1
Hi Barbara.
Do you have an email to send the XLSForm?
Thank you.
BarbaraWebster1
Hi @HaroldHerrera1,
Yes, you can send it to bwebster@esri.com
-Barbara
HaroldHerrera1
