Repeated geopoint to drive dashboard map
234
01-22-2025 03:43 AM
JamesTurner2
I have a workflow which uses a survey123 for embedded in a dashboard for data review. The dashboard has three parts, a list to navigate between responses, a map to visualize the survey responses (driven by list), and the embedded survey. The survey collects a point when it is started and it also has a repeated geopoint question. Sometime the reviewer needs to open the geopoint map and evaluate the surrounding area for specific details. It seems cumbersome to click to open the map, zoom to scale, and then navigate. Is there a way to connect the geopoint to the larger map in the dashboard so going to the next geopoint triggers the map to move?
