Relevant for pulling data from geopoint
1240
11-30-2017 11:55 AM
BrentKinal1
I would like to hide my horizontal accuracy field if a geopiont is manually entered. Can someone recommend syntax for the relevant clause?
Thanks!
JamesTedrick
Esri Esteemed Contributor
As indicated at Geopoints—Survey123 for ArcGIS | ArcGIS, the function to get the horizontal accuracy is pulldata('@geopoint', ${location}, 'horizontalAccuracy') .  When a point is manually set, this value becomes null:
The appropriate relevancy calculation is
pulldata('@geopoint', ${location}, 'horizontalAccuracy') != null
JamesTedrick
BrentKinal1
Perfect! Thanks.
