Question Alias in feature service for hidden question
1512
06-03-2019 11:49 AM
RussellSturm
When looking at submitted data from a survey, why do the hidden questions not pick up the full question text?
Example:  the column name is estimatedfivesilkdate and the label is "Estimated 5% Silk Date" -- in the feature service I see the column name but other questions are showing the column label.  The one that is now showing the column label is a hidden field.  Is there to get that to show the label like the other columns?    See attachments.
JamesTedrick
Esri Esteemed Contributor
Hi Russell,
As the label column is not explicitly used on hidden and calculate fields, the alias needs to be placed at the bind::esri:fieldAlias column.
JamesTedrick
Hi Russell,
