Query -> Table Widget Action Difficulty
77
yesterday
SteveCole
Honored Contributor
I'm probably dense because I just find EB workflows too confusing but I'm having difficulty getting an action to do what I want.
Backstory- I'm developing a very simple EB based front end to allow my users to export S123 records to CSV. The S123 has a feature class with 2 related tables (there are 2 repeat sections in the survey). The EB project only has a Query widget and then a Table widget below it. The Query widget is associated with the S123 web map that contains the feature class and the Table widget also points to the same S123 feature class & related tables.
Desired Workflow- Ideally, my users would select the desired records using the Query widget and then the Query widget would then select the same records in the Table widget using the Query Widget's Action. But it's not happening even if the Action pane infers that it *should* happen-
I've tried developing this initially without a Map widget and now with a map widget (hidden behind the table widget since it's not needed visually) and I can't get the Query widget to auto update / filter the table widget contents.
Before anyone asks, I know you can export records through the Query widget but I don't like how the actual export tool is buried in the interface, especially for the 2 related tables. At least with the Table widget, the user can just switch tabs and the export button is there.,
JonM32
@SteveCole
I recently discovered the Manager Instant App and used it for Survey123 survey management. I was able to set it up with the feature layer associated with a survey, allowing others to edit results. There is a very simple, easy way for end users to export the results to a CSV built in. You may be able to use this out of the box or configure it for what you described above.
Manager—ArcGIS Instant Apps | Documentation
311 Requests - Street Conditions (Esri Example)
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
SteveCole
Honored Contributor
Thanks Jon for highlighting that Instant App as I wasn't familiar with it. I neglected to mention that I'm attempting all this inside Portal version 11.5. The Manager Instant App is available to me but, right now, I'm just getting a spinning circle when I launch the app. Clearly I'm doing something wrong so I need to read up on it. Only thing I don't like is it being map based. My S123 use isn't map dependent.
