I am (still - or again ;-)) working on an agricultural survey. I have a repeated group that is asking for the planted crops in a plot. When the number of planted crops is e.g. 3 the survey creates 3 repeats. Each crop is recorded with the according share (e.g. 70/20/10 percent). How can I
1.) check if all fields were filled for each repeat. I have something in the far back of my head that constraints were / are not working well within repeats.
2.) check that the total of all crops is 100%?
Thank you people!
What you would want is the sum() operator, which would add up the value of a field across repeats. We currently do not yet have support for that function.
Thank you James. Is the sum() function somewhere among the things that is planned to be implemented soon?
As I have just seen the constraints should work now within repeats. (Required Fields ignored in repeats · Issue #226 · Esri/Survey123Community · GitHub ) So at least I could check if the fields are not empty.
