Pulling Data from Previous Select One From List in Survey 123 Connect?
290
03-26-2024 06:34 AM
CamTurney
New Contributor II
I have a repeating group, and within the repeating group, is a set of questions that can repeat as well. In the base group, I have a select one from file for species name. Then, I have an optional set of questions about that species that repeat for individuals that need to be tied to that species in the attributes when exported. I created a hidden and started a pulldata formula in calculations column to try and pull the answer to the original species select one from file question. However I cannot get it to grab the data.
This is my form:
This is my list:
I have tried tweaking things but have had no success with the species coming up. Any help is appreciated!!
jcarlson
MVP Esteemed Contributor
Check out the S123 docs about pulling values from indexed repeats. You should be able to reference other repeats in the form.
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformrepeats.htm#ESRI_SECTION1_F3E28755...
- Josh Carlson
Kendall County GIS
CamTurney
New Contributor II
Unfortunately this did not work either. I used the position(..) and index-repeat and I got 0's returned for each species repeat index, and nothing returned for my index recall (indiv_name).
