Pulldata returning error message
11158
23
02-12-2018 12:32 PM
KendraStraub
I have loaded external data into the media folder in my Survey123 folder.
GRSM_species_list is the exact name of the csv in the media folder.
cover_lookup is another csv in the media folder.
I am not sure how to interpret the error message I am receiving. #
When I publish the form I get the following error message:
Error: Initialing Form...
  • External instance "GRSM_species_list" is empty.
  • FormLogicError: instance "cover_lookup" does not exist in model
by Anonymous User
Not applicable
Hi all,
I am running into a similar issue with getting thing to run on the web app. I receive the same error "FormLogicError: instance "itemsets" does not exist in model". I have ran through a few things that have been mentioned above with out much success. I must be overlooking somehthing if you could take a look.
JohnathanHasthorpe
Hi Kyle - there was an issue with where you put the pulldata() function. I moved it to its own separate question to get it to work.
Please see attached.
by Anonymous User
Not applicable
Awesome that got rid of the error. Now what I am seeing is it is not recording the geopoint or location on the data end, What might be causing this?
by Anonymous User
Not applicable
@Johnathan Hasthorpe I solved my Issue. I had a relevancy set on my geopoint which was preventing the location data from being recorded on the back end when the criteria was not met. \
Thanks again for the help,
-Kyle
