pulldata() missing some records
1677
03-17-2017 07:57 AM
ErikLeigh
I'm trying to use the pulldata() function as a license record lookup to populate data in a form header.  It seems to work almost all the time, but for some reason it will not return specific records when chosen and I can't figure out why.  It doesn't seem to be a coding issue because it works just fine on other records using the exact same parameters in pulldata().  I thought maybe there were some sort of text character issues, but again, I can't figure out what.  Any suggestions would be appreciated.
ErikLeigh
LicenseNumberEstablishmentOwner NameOwner EmailLocation Addr Line 1Location CityLocation County
F22AMERICAN LEGIONAMERICAN LEGION POST #19 110 E 3RD AVEBIG TIMBERSweet Grass
F28EAGLES STOREEAGLE COMPANY INC[email protected]3 CANYON STWEST YELLOWSTONEGallatin
F29STOCKMAN BAR & CASINOT J T105 MAINROUNDUPMusselshell CO/Central MT Hlth
F31VFW BARVFW POST 276 20 BAKERWHITEFISHFlathead
F35EAGLES CLUB FOE 689F O E # 689BOX 518CHINOOKBlaine
F38VFW CLUBV F W 218 S MERRILLGLENDIVEDawson
F105CORNER BARPEGGY A ROST3212 EUCLIDHELENALewis and Clark
F119SWAN VALLEY CENTREAAA QUALITY SERVICES INC6799 HWY 83/MILE POST 42CONDONMissoula
Just an example of my data and code I've tried using. The yellow highlighted rows fail to return anything.  The other records work just fine.
JamesTedrick
Esri Esteemed Contributor
Hi Erik,
Is it possible to create a select_one from your LicenseNumber column and test that? I'm not seeing anything obvious (unless there's extra white space in some values- you might want to open the CSV in a text editor and check).
ErikLeigh
Hi James,
Thanks for the follow-up. I would rather not do a select_one as a permanent fix. There are over 11 thousand records in my full data set. I could erase the majority and test it however.
Sincerely,
Erik Leigh, RS
Montana DPHHS
Food and Consumer Safety Section
1400 Broadway, Room C-214
Helena, MT 59620
406-444-5306
[email protected]<mailto:[email protected]>
