Pulldata in relevant field
934
02-14-2022 06:03 AM
by Anonymous User
Not applicable
The Pulldata not working on the web form, on the relevant field? I made a form and Pulldata only works in the Survey123 APP
There are 102 questions that will only be relevant if the expression pulldata return TRUE
This is the expression: pulldata('pergunta','av1','categoria',${categoria_manejo})='TRUE'
  • FormLogicError: instance "pergunta" does not exist in model
IsmaelChivite
Esri Notable Contributor
At first sight, it looks like you may have a typo in pergunta. Should not this be pregunta?
Hard to say without looking at the XLSForm. Here is a shot in the dark. May be this does it:
  1. Add a new question:
    1. Type calculate
    2. Calculation: pulldata('pergunta','av1','categoria',${categoria_manejo})
    3. bind::esri:fieldType: null
  2. In your relevant statement: use ${question1above}='TRUE'
by Anonymous User
Not applicable
Hi @IsmaelChivite
This is the form. It works normally in Survey123 field app but not in web form
