pulldata from another survey while offline?
1660
07-19-2022 12:42 PM
PaulPetersen1
Kind of a crazy question, but is it possible to pull data from another survey on my device? Basically need to populate a question in my main survey by querying and pulling from another survey. Needs to work in offline mode, so querying the feature service via javascript is not an option.
Tags (3)
ZacharySutherby
Hello @PaulPetersen1
This is not possible currently with the out of the box Survey123 field app. The best way to accomplish this would be to create an add-in that is able to retrieve records from Survey123's backend database. At this time add-in's are in beta, please check out our Early Adopter Community for more information on add-in's in Survey123.
Thank you,
Zach
PaulPetersen1
Thank you for the info Zach. I'll look into that.
