PullData Constraint not working in webform
10021
11
01-03-2019 08:35 AM
MattCobb
I have a 'Participant ID' field that references a csv list of unique codes that will be sent to individuals to complete the survey.  I entered my pulldata formula in the Constraint field for the Part_ID field, and it works flawlessly in Survey123 Connect.  But when I publish to webform (which is how the survey will be accessed), values that match the ID's still return a constraint error.
I've attached the Survey, the ID.csv, and a screen grab of the webform error.  Thanks for any help!
ScottMoore__Olympia_
Here is an example of using pulldata to validate a set of "codes" in a csv.  It works in the webform as well.
AndrewPadilla
Thanks for your help Scott. The validation is working well!
