Pull date from csv and use in calculate (type mismatch)
6587
04-25-2022 02:58 PM
js80540
Hello,
I have seen this question pop-up a few times but never really any official answer.
I am pulling a date ("2021-04-01") from a csv file, which I would like to ingest in a form as a date object (using date()) in order to add 21 days to it and check against current date.
I am stuck at the first step though, I can't seem to be able to convert the string of a date to a date object.
So with my date being pulled from the csv and equal to '2022-04-01', stored as test_dob. date(string(${test_dob})) returns mismatch error, but if I do date(string('2022-04-01)) it works no problem.
So it makes me wonder how this date actually get stored in the back-end.  And why it displays perfectly but doesn't get ingested as expected in the date function.
I have attached a csv sample and the table from which i am trying to pull (names are fake by the way). I am using the last S123 Connect
Thank you very much for your help.
Tags (3)
DeonLengton
Hi
I simplified it and this is the result:
I hope that is the outcome you were hoping for. Here are the calculations:
pulldata('permits','date_to_pull','name',${permit_number})
${test_dob}+21*24*60*60*1000
The first one is still as you had it but i changed it to be a date type.
datetest_dobDate of birth
The second calculation adds 21 days to the test_dob date.
Hope that helps.
DougBrowning
MVP Esteemed Contributor
My guess would be using the word Date as your column name.  That is a reserved word in SQL lite.  Try changing it.
js80540
I actually just changed it for the sake of clarity before posting here, this is not the source of the issues unfortunately. Here are two updated files renamed.
Thank you!
DougBrowning
Yea i cant get a pulldata and date to play nice either.  Did you try doing a note, take off the date() part then just bind esri type to date?  Might work.
Looks like date may need a certain format also.
date(question, expression, or value)
Converts a number or string to a date object, without preserving time.
date('2017-05-28T04:39:02+10:00')
Sorry all I got
DeonLengton
Hi
Hope that helps.
js80540
Oh wow! Thank you!
I really wish this was mentioned in the documentation, a few other people seem to have the same issue on the forum since the documentation suggest using date().
Thanks again!
