Pull data does not populate when trying to edit in browser
819
04-16-2020 08:48 AM
AlexanderCottone
Hello,
I have a survey that relies on the pulldata function for a significant portion of the survey. Once the user submits the survey, they then receive an email generated from microsoft flow that contains a link to edit the survey.  When I open the link, however, the fields that utilize the pulldata function are empty.  The data is correct when I view it in the data view.  Will this not work similar to how the pulldata function does not work in browser? If so, are there any other workarounds? I know you can edit submissions directly from the app, but I want to establish an easier workflow for the people who would be filling out the survey. Thank you for your help.
Best
JamesTedrick
Esri Esteemed Contributor
Hi Alexander,
Apologies for the delay.  The questions populated by pulldata should act the same way as any other question.  Troubleshooting this would require looking at the form and webhook setup; this is best done via Esri Support- if you can, please file a support ticket.
