Pull back read only data to a survey 123 form
1103
08-27-2024 08:09 AM
fitzpat_s
We are going publish data on ArcGIS Online from excel. The user will select a value (ID) from a drop-down in Survey 123 that will correspond to 1 or more rows in the excel data. We then want to display this data into fields in Survey 123 as read-only. Each matching row (ID) will have 8 fields. and we would like to collapse & expand the matching ID to display the additional data fields so it is isn't unwieldy. Sometimes there will only be 1 matching ID but often there will be >1 . Would the "Pull Data" function be what we would use here? - thanks for any help on this
abureaux
MVP Frequent Contributor
You will need to populate a repeat if there are multiple records. query could work for that.
Survey123 Tricks of the Trade: Repeats (info on query is near the end).
abureaux
