Public Survey123 and public Feature/Map Service Integration
1035
06-06-2025 05:41 AM
AbiDhakal
Dear GIS Friends,
I have a public Survey123 form that I would like users to interact with, allowing them to drop a Geopoint, which would then automatically pull information from a public feature/map service. However, I've encountered a roadblock. Specifically, it appears that the pulldata("@javascript") function cannot be used with public services. Is there another way I can achieve this?
I understand that if the survey were shared privately or within the organization, the process would work. But when both the Survey123 form and the feature/map service are public, pulling data seems to be problematic.
It would be very helpful if the information could auto-populate as the user is filling out the survey. Is there a way to make this possible?
From what I understand, creating webhooks can populate data from a public service, but only upon submission, meaning the users won’t be able to view the information while completing the form.
Your help would be greatly appreciated.
Thank you,
2 Solutions
Neal_t_k
MVP Regular Contributor
AbiDhakal
@Neal_t_k - This worked perfectly.
Point-in-polygon query to retrieve multiple attributes: pulldata("@layer", "getRecordAt").
Thank you for your awesome help.
Abi.
Neal_t_k
AbiDhakal
Abi.
