Public survey not working when published from enterprise
1674
11-17-2020 12:52 AM
Jon_Tait
Hi, I've used Survey123 successfully many times when creating and publishing surveys from ArcGIS Online (AGOL). But when I try and create a public survey from our work Portal I get an error when opening the survey on anything other than the laptop I created it on that says:
"This survey does not exist or is not accessible"
The survey is shared to Everyone(Public) and is open for responses.
Am I doing something wrong? The URL for the survey is https://survey123.arcgis.com/share/a60c43739bc74dc099a2147384693dfa?portalUrl=https://arcgisinternal...
Many thanks
Jon
Environmental Control Officer
East Riding of Yorkshire Council, UK
DavidColey
MVP Frequent Contributor
HI Jon - you might have to enable anonymous access to the portal. If that is already enabled, then I don't know...
Jon_Tait
Thanks David, I'll pass that on to our IT team and see if they can fix it
Jon
