Problem With S123 Custom Reports
947
09-18-2019 12:05 PM
DoriBroglino
When I try to print output from a multiple choice question it does not show up in the custom report.  See screen shots below. All fields print fine when using the Standard Print option.  Is it possible to get the code used to generate the Standard Print report. This may help.
The "Condition(s) required for approval/disapproval" field  won't print using my code in the Custom Report.  In creating my custom report I am copying the field name directly from the template.  The field name is definitely correct.  It's a response to a Multiple Choice question that allows multiple responses to be chosen as well as an Other option.  The first bullet is one of the multiple choice choices. The second bullet is the typed in Other response.
Here is the code I used in the custom report:
Here is the output that I get when the custom report is run:
It does not pull the data I the "conditions_required_for_approva" field.
I'm guessing there is some additional coding required to get multiple responses to print?
Thanks for any help.
DoriBroglino
Disregard this question.  I got it to work.
I can't figure out how to delete the question.
