Problem with Cascading select with choice filter
6469
11
11-03-2017 06:31 AM
Siew_WeiGoh2
I am not sure what I'm doing wrong here but I am having issues with Cascading Select. I have tried changing autocomplete to minimal, but it still doesn't made a difference
My survey setting:
My choice sheet:
I am not getting the result I'm expecting - unable to select segment:
Please advice.
Thank you
SW
LindaSyers
I had this issue too.  After a lot of hair pulling, I figured out that it was because my table name had periods in it.  This is done by default when a feature class is created in the SDE, so it is published with a prefix of geodatabase.DBO.table_name.  Since the form is published from an existing service, I can't change the name in the form to remove the periods.
Does anyone have a work around for this?
IsmaelChivite
Esri Notable Contributor
Hi Linda. You can rename the tables in the Table of Contents in your ArcMap and ArcGIS Pro document and then publish the service again. The Feature Service names your tables and layers according to the table of contents in your document. You do not need to rename your tables and layers in SDE.
