Problem uploading survey
4360
12-17-2015 10:29 AM
MaryWasson
Once I have completed my survey on my mobile device and click the green check, it does not give me the message that my survey was uploaded.  I do not see any data I have collected.  What am I doing wrong
HannahFerrier
When you select the green checkbox to finish your survey, you will have the option to either **send now** or **send later**. If you do not have an internet connection, you can only send later.
Surveys that have been saved to send later can be found in the **outbox** for your survey:
Open your outbox when you have internet connection to submit your surveys.
Sent surveys can be reviewed in the **sent** box:
Hope this helps,
Hannah
FasilTiru
Hi Mary,
Please take a look at this thread as the issue that you experiencing seems similar.
What's wrong with my XLSForm?
Fasil T.
HannahFerrier
Hope this helps,
Hannah
