Power Automate - The dynamic schema response from API 'survey123' operation 'GetWebhookPayloadSchema' is too large
2931
06-04-2024 04:52 AM
LydiaCarey
Hi, It seems that many people have had this problem for multiple years now and every discussion post never seems to find the solution. So I'm here to bring it up again to see if this is something that's still not fixable.
The dynamic schema response from API 'survey123' operation 'GetWebhookPayloadSchema' is too large, only schemas with at most '1024' properties are supported.
Has anyone figured out a work around for this at all? I saw the set Include Submitted Record to No but when I do this my trigger never seems to work and set off my flow. My survey itself has less then 1024 lines but it also has pull data. the feature layer itself has way less then 1024 fields.
RHammers
@LydiaCarey  Did you ever get this resolved? I'm having the same issue.
LydiaCarey
No idea what I did but eventually my trigger started working even when Submitted Record set to No.
