possibility to use a json response as a selection list
1893
05-06-2022 01:07 AM
GISKoordinator_LK-SPN
Hello,
since some time it is possible to query services via java scrip (pulldata@java) and parse the response via @json.
My question now would be, is it possible to create a new selection list from this response and use it in the survey (as a cascade or similar) ?
I think that such a function would be very useful if online data changes very often and you always want to work with the latest data in the field.
Tags (3)
IsmaelChivite
Esri Notable Contributor
What about using a dynamic list? They allow you to populate a list using the results of an attribute and/or spatial query. Check this article for details: https://community.esri.com/t5/arcgis-survey123-blog/dynamic-choice-lists-using-search-appearance/ba-...
IsmaelChivite
Hello Ismael,
this is exactly what i was looking for.
thanks for this
