Populate data from XML
2654
6
03-29-2018 09:50 AM
HeathAnderson
While connected to the internet is it possible to populate suvery123 fields from an xml page?
https://aviationweather.gov/adds/dataserver_current/httpparam?dataSource=metars&requestType=retrieve...
by Anonymous User
Not applicable
Hi Heath,
It is not currently possible to populate answers in a survey from an external xml page or other web based source. This is a feature enhancement we have in our backlog and I have updated your comments above in the backlog issue.
Phil.
by Anonymous User
Not applicable
Hi Heath,
Phil.
NathanBruce1
Phil, is this still applicable, we are looking for the same solution, that is to pull weather data into a survey from xml
HeathAnderson
Hi Nathan,
I currently have a METAR layer in AGOL that populates weather data.  I then use a configured Web Map to open Survey123 on the device.  Is this what you are looking for?
NathanBruce1
Heath, that's good to know, appreciated.  We were looking to auto populate a survey form, which is for Municipal Route Patrol without involving too much in/out activities for the user.  I think we working towards the JS function from below.
by Anonymous User
Not applicable
Hi Nathan,
This can now be done via custom JS functions in Survey123 using the pulldata @ javascript feature. It is currently in beta and documentation about how to do this is in the Early Adopter Community.
Phil.
NathanBruce1
Thanks Phil, we are exploring this route, using your template.
