Passing a date via a field URL parameter || format issues
1664
09-23-2024 08:11 AM
Sven_Harpering
Hey all,
we created a form using the Survey123 Web Designer and then integrated this form into an ArcGIS Dashboard using the "Embedded content" widget. The form should be called when a feature has been selected in the map. This works so far! 🙂
Our observation is now the following: If the feature contains a date including the time, it will only be transferred from the feature to the form via a field URL parameter if the settings of my AGOL account are set to English, as well as the time format is also set to English. In the other case, here a German profile with the German time formats, the transfer does not work and the field in the form remains empty. Is this a known limitation?
Best regards
Sven
Passionate about GIS and on the journey as an instructor for analytical insights.
abureaux
MVP Frequent Contributor
(Disclaimer: Nothing I've encountered personally. I only use NA settings)
Have you inspected the output yet? The easiest method may just be to feed the date into a text field and see what changes. Once you know that, you can feed the date into a calculate which modifies the date into a format the Date question can handle, and then feed that calculate into the Date.
abureaux
Sven_Harpering
Hi @abureaux,
thank you for your reply. I have tested your idea with the text field. I think I know where the problem is. Using the German profile I am getting the following output:
As you can see: Day and month are switched comparing the textual output and the output in the date question. If I am now getting a date like this:
The date question is empty. This makes sense, because the system switches the day and month in the background and tries to set the value 16 as a month. That is not valid.
So I think I will maybe report a bug.
Thx for your help.
Best
Sven
