Pass Username and Date to Survey123 Form
2242
12
12-08-2023 10:02 AM
kapalczynski
From Field Maps and a webhook I can pass the Global ID to a RELGlobalID like so
field:REL_GLOBALID={GLOBALID}&
href="arcgis-survey123://?itemID=cb33fc9a37xxx440146&amp;field:REL_GLOBALID={GLOBALID}&amp;callback=https://fieldmaps.arcgis.app" rel="nofollow ugc" target="_blank">Add Form</a>
But Im curious how to pass the Current Date to a date field and the logged in user to a username field
1. Can I use the NOW to denote existing date and time?
           field:SomeDateFiled={NOW};
2. What about the logged in user?
            field:UserName={username};
kapalczynski
where do you assign the hidden field to the username field
DougBrowning
MVP Esteemed Contributor
There is now a field type of username, not sure the diff.
this post may help  https://support.esri.com/en-us/knowledge-base/how-to-assign-questions-based-on-user-roles-or-usernam...
abureaux
MVP Frequent Contributor
The username type should pull the user's username, whereas the pulldata("@property",fullUserName) would pull the full name... I think a picture does this explanation better justice:
