Outbox send errors
571
09-29-2025 10:48 AM
TheresaLowe
Survey123 Outbox: Error message "You do not have permission to send these surveys". I am signed into Survey123, but I wasn't when I made the surveys. Does this have anything to do with why it will not send these surveys? The tablet is connected to internet and has service but still will not send the surveys from the outbox. It keeps coming up with message: !Send error: Message not sent: 1 . How do I fix this and get the information to send?
Neal_t_k
MVP Regular Contributor
Have you checked that the right security setting are applied in the Survey123 settings as well as the AGOL settings?
Have you done any updates lately to the form that would change the view that the form is submitting too? i.e. are the forms in the outbox point to an out of date version of your form?
TheresaLowe
Good questions. How do I check the security settings applied to Survey123? I will check in with where this form gets sent and see if they did any updates or if I am using the latest version as well. Thank you.
