Options for changing default active repeat record when opening form via inbox
877
11-24-2025 02:00 PM
mattkramer
I was curious if it was possible to configure the default record users are presented with when opening a form containing a repeat from the inbox. By default, forms load to the first repeat record, and I would like this to be updated to the last.
Was just looking to check that I am not missing any functionality before opening an idea.
Thank you!
DougBrowning
MVP Esteemed Contributor
No there is no way.  But if you long press the right repeat arrow it brings you right to the end.  So it helps
DougBrowning
mattkramer
I did not know that! Thank you for the helpful tip. I think that will work for us, at least for now.
