Operation Rolled Back
1229
07-06-2020 10:02 AM
MauricioGiraldo
Dear all,
I have tried to follow your advices about how to solve the issue with "Operation Rolled Back" in some repeats option into my form.
In advance, thanks for all ypur support!
James Tedrick
JamesTedrick
Esri Esteemed Contributor
Hi Mauricio,
Apologies for the delay.  I did not see an 'operation rollback' error in submitting with the form you attached.  Operation rollback normally occurs when there is too much text for a field or a value is otherwise too large to be stored.  It looks like you mostly have integer questions; allowable values for an integer question are between
-2^31 (-2,147,483,648) to 2^31-1 (2,147,483,647)
