ODK Validate Errors in geopoint where same relevant works in other field types
1757
05-22-2019 04:51 AM
WhitneyWeber
I'm attempting only to display the geopoint field based on a relevant formula which is successful in two other note fields (sf_line, sf_poly). I cannot find anything in the calculate/relevant expressions relying on the same field twice which would cause the dependency cycles. Do I have something wrong (although it works for other fields) or is this just because it's associated with a geopoint? Is there a different way to achieve this? The spreadsheet is attached for anyone who would be so kind to review it.
JamesTedrick
Esri Esteemed Contributor
Hi Whitney,
The issue is the loop between the horizontal accuracy, which affects the loc_uncert questions, which affect pre_sf_type, which affects the geopoint, which affects horizontal accuracy (and loop).
JamesTedrick
Hi Whitney,
WhitneyWeber
Thanks, James! I appreciate the help!
