No error details described while converting xls form
1074
03-25-2022 11:43 AM
KerryKang
Hello all,
I've noticed my Survey123 Connect does not show any details where errors were occurred while converting xls form. I've used both 3.13.251 and 3.14.26, and observed the same behaviour.
I found it's really tricky as my survey has over 100 rows and make big changes in the overall set up. Is there a way I can see the error details?
Thank you.
Kerry
Katie_Clark
MVP Regular Contributor
Hello! See this post - the Esri Survey123 team is looking into this. It's related to an issue with a web service, apparently.
https://community.esri.com/t5/arcgis-survey123-questions/error-converting-xlsform-survey123-connect-...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
