Nested repeats
1024
02-20-2020 02:00 PM
AnnaMorris1
Hi Everyone,
I am new to Survey123, and am trying to set up 3 related forms (i.e. Form A,B & C), each with a one to many relationship. At form A, I just need to be able to collect the date, then I need to be able to add multiple entries of Form B. From form B I then need to be able to place a point and collect additional information (From C). This seems easy feasible to set up when there are 2 related forms, but I am struggling with the workflow to make this happen with the 3 levels, as nested repeats are not supported in the web app. I have tried following a version of the workflow used here: https://community.esri.com/thread/181809-survey123-feature-class-as-a-related-table but with no success. Is anyone able to provide any insight on this?
Than you in advance!
Anna
DougBrowning
MVP Esteemed Contributor
Can you use Connect instead?  Then no problem.
