Nested Repeats Not Working with Polyline
1431
04-18-2019 08:59 AM
by Anonymous User
Not applicable
Here is the link to my survey: https://arcg.is/riTCi
My excel file is attached
I used the Beta Version to Create. My nested repeats worked fine when I created the Survey in Connect, but the attached one which was created from a feature service is just not working.
When I try to refresh inbox or submit report it gets stuck on "Getting service information (INSPECTIONIMAGES)"
...just spins and spins
See attached picture. Any help is greatly appreciated!
JamesTedrick
Esri Esteemed Contributor
Hi Brita,
The issue appears to be with the existing feature service - by chance, was this published from ArcGIS Pro recently? The numbering of the feature service skips a number between the layers entires and table entries.  This will be fixed in the next version of ArcGIS Pro.  As a workaround, could you try to export your data as a file GDB and create the service by uploading it into ArcGIS Online via the web page?
