Multiline text limit error
2901
6
07-15-2025 01:15 PM
RobbHodges
We recently upgraded our surveys to 3.23. Before that, all of our Multiline text fields had a limit of 1000 characters. It appears to still be that way when filling out the survey through a web browser.
However, the survey123 app is limiting us to 255 characters. This is the case with every survey we have. Again, that same survey allows the full 1000 characters when using a web browser.
The surveys are all created with the web designer.
Has anyone else come across this issue? We had a bug logged for this, but they combined it with an older, similar bug. But, this just started for us with this latest update to the survey.
ChristopherCounsell
MVP Frequent Contributor
You need:
  • Fields that support 1000 characters
  • A form that allows for 1000 characters and recognises the underlying field length is 1000
When you first published a survey it will:
  • Create the field with a set length (e.g. 255)
  • Retain this value within the form, so that the user doesn't enter more than 255 characters
If you change the field length you also need to republish the survey form. This means:
  • If you've manually deleted the field and recreated it via ArcGIS online, you need to also republish the survey form and set the schema to match the new length. In connect this is a column. In web designer I believe it's in the schema preview.
  • If you reconfigure it via the survey interface and republish, it may delete your field as part of the process
Then in your field app you need to re-download the updated survey form.
Try stepping through the above (field, survey schema settings, and updated form) to see where the discrepancy is and if republishing the survey resolves it.
RobbHodges
Hey Christopher, so the field is set up for 1000 characters and has been since I created the form. This is happening in all of our forms. Ive tried republishing quite a few of them. This happened after republishing them to version 3.23. Up until now, our field crews have been able to leave detailed comments.
Neal_t_k
MVP Regular Contributor
@RobbHodges If you go into your survey folder in "My Survey Designs" parent folder and open the YourSurveyName.webform and the YourSurveyName.xml in a text editor and compare the field length for that field from both.  They should be the same at 1000.  Not sure how that will help other than trying to figure out where the error is happening.
RobbHodges
We only run this in the web designer. So, I don't think I can get to that. I did notice that even when I create a new Multiline field, it still limits me to 255 in the app, even though I double checked in the schema that it is set to 1000.
CClark
We are experiencing the same thing.  Survey created in Web Designer about 3 years ago and multiline field has always been set for 1000 characters.  After making a small change to an unrelated field and saving, it is now 255 characters.  Length still shows 1000 in the Feature Layer service and is not set to a value type.
RobbHodges
Other than going in and recreating that field, it looks like we are out of luck for now. I have gone in to 34 surveys to remove the original multiline text fields and replace them with new ones (you have to go into the schema before you publish and change it to 1001 characters). Let's just say that hasn't been as fun as it sounds. There is a bug out of it, but it's still in the Under Consideration phase.
