Moving points around on a map.
1818
08-27-2019 04:51 PM
ToddAckerman
I collected my points in survey123 connect and then put the points on a map in ArcGIS Online, I did not use a good GPS so I need to move the points and put them in spots closers to where they are actually located. I am missing something in trying to edit my points on my map.
by Anonymous User
Not applicable
Hi Todd,
Are you trying to edit the location of you points in the web map in AGO or in the geopoint detailed map in the field app?
Phil.
ToddAckerman
I use ArcGIS online and it is when I bring back the data to my desktop.  I am new and am working somethings out.  My knowledge is gaining but the learning curve is still going up.  Thanks.
Todd
by Anonymous User
Not applicable
Hi Todd,
Yes you can edit the location in an AGO web map, using the edit feature button and then selecting the point you want to edit and moving it to a new location.
Phil.
