Mismatched Brackets
1904
06-06-2022 12:52 PM
SamThach
I am writing a calculation for a bunch of variables and keep getting the error about mismatched brackets. I do not see what is wrong since I count that all brackets are there in the right spots. Anybody know what is wrong? I tried this into a simpler one located down below but got the same error.
original:
IF(selected(${sidewalk},"yes"), (int(${obscured_adress}) + int(${broken_windows}) + int(${yard_debris}) + int(${untrimmed_yard}) + int(${roofing_cond}) + int(${paint_exterior_cond}) + int(${physical_appearance}) + int(${sidewalk_kind})) , (int(${obscured_adress}) + int(${broken_windows}) + int(${yard_debris}) + int(${untrimmed_yard}) + int(${roofing_cond}) + int(${paint_exterior_cond}) + int(${physical_appearance}))
simpler test:
IF(selected(${sidewalk},"yes"), 1, 0)
DougBrowning
MVP Esteemed Contributor
Did you try if it may be case sensitive and not know what IF means.  Just a guess.
RobertBorchert
Honored Contributor
You have 19 start ( and only 18 closing )
Trouble shooing Tip paste it into Word and use the search function to count the number of each.
DeonLengton
Better yet, use Notepad++
If you highlight a bracket it will show its closing bracket, if it exists...
IsmaelChivite
Esri Notable Contributor
This works for me. I just added an extra parenthesis at the end and replaced IF with if
if(selected(${sidewalk},"yes"), (int(${obscured_adress}) + int(${broken_windows}) + int(${yard_debris}) + int(${untrimmed_yard}) + int(${roofing_cond}) + int(${paint_exterior_cond}) + int(${physical_appearance}) + int(${sidewalk_kind})) , (int(${obscured_adress}) + int(${broken_windows}) + int(${yard_debris}) + int(${untrimmed_yard}) + int(${roofing_cond}) + int(${paint_exterior_cond}) + int(${physical_appearance})))
Attaching another approach to do this
