Misc. errors: photos and records not syncing
3743
7
06-22-2017 01:40 PM
SofiaThordin
Okay, I'll preface this by saying I am novice to GIS Online/Apps. I am using Survey123 to survey historic buildings. I published surveys using Survey123 Connect (may have errors in my XLS, but I have tried proof-reading). I am pre-filling forms using Survey123 Desktop at the office and have no issues at all creating/pre-filling survey forms. HOWEVER when I go into the field using the iPad Survey123 App Inbox (online with cellular data), images do not send and select_multiple lists do NOT save.
For example, I pre-fill Building A with:
  • Image: blank/no attachment
  • Architectural features: beanpoles, louvers
I go out into the field using the Inbox and want to make edits. I add an image and add some other features, I hit "Send Now" and the changes are not reflected. I.e. the edited survey looks the same before and after editing. Changes for Text, Select_one, and Geopoint have no issues, they all save perfectly fine. Note: the select_multiple changes do not even show up in the Sent folder on the local device.
My current workarounds:
  • Select_multiple issue: I am able to FORCE the changes by going through the back-end. I open my feature service in ArcGIS online, go to the field I want edited for a point, manually copy/paste the item name into the attribute list, and hit save. Only then will the box be "checked". When I "check" it from Survey123 App, the change is not recognized. Note: the boxes I check while generating a new survey will save, it is only once I want to edit the survey that the boxes are "frozen" to their original submittal status.
  • Image issue: I am able to recover the images by going to the Sent box on the iPad, selecting "copy sent data to new survey" and hitting submit. Note: this ONLY works when I am back at the office connected to Wifi.
I am hoping this is just some silly error in my spreadsheet, but I can't understand why the initial survey send will save everything, but edits will be ignored for some question types, but not other question types. I also am confused as to why the images will not send from the Inbox with cellular data connection, but will send as duplicate copies from wifi using local device "Sent" box.
More info: My feature services have editing enabled, they are not shared since I am the only one using the data. My form settings are not linked to a URL since I have been unable to understand how/why that field exists. Survey123 Connect v. 2.1.9, Survey123 desktop app v. 2.1.6, iPad Survey123 app v. 2.1.6. I am running Windows 7 and the newest iPad ios 10.3.2.
JamesTedrick
Esri Esteemed Contributor
Hi Sofia,
On the images, we currently do not support using the inbox with images (attachments).  On the select_multiple, I can see the behavior you are reporting and have logged it as an issue.
LarryWiebe
Hi James,  Is there a time frame to support image collection for an inbox based survey?
Larry
JamesTedrick
Hi Larry,
We currently don't have a time frame for image collection specifically, though it is a high priority.  We are currently working on supporting editing forms with repeated sections and hope to have a beta build available in the Early Adopter Community soon.
MathieuBoonen
Has the Inbox based photo issue been resolved, I am using version 3.x of Survey 123 and other users data that I wish to view captured photos they captured but on my device if possible.
LarryWiebe
Hi Hikurangi Forest,
When I got involved in this thread it was not possible to collect new photos on an Inbox based survey or to take existing photos back out into the field for reference.
I found, with the help of others, posts that allow you to set up a repeat with an image question in it that will allow you to collect new photos.
As far as I know there is no way to take existing photos back out to the field as part of the Inbox functionality at this time.
Collector will allow you to take existing photos out to the field if that is an option.
Thanks, Larry
MathieuBoonen
Thanks Larry
Will Collector allow you to have these photos in an offline sense (in the bush so to speak) without internet connectivity?
Tall Aks I know but I have to ask.
Regards
Mat Boonen
pp Hikurangi Forest
LarryWiebe
Hi Mat,
Yes, Collector will take photos out to the field in disconnected mode.
You need to have the photos as attachments in your feature service. The feature service also needs to have “sync” capabilities enabled. It can be tricky to get going, but once up and running is quite stable.
Larry
