Mask Causing Strange Cursor Shifts When Clearing An Answer
1865
10-13-2016 10:19 PM
WengNg
Hi All,
I found a strange issue where the input cursor shifts to somewhere in the middle instead of returning to the start of the input when I attempt to clear an answer (using the X button) on the form in a question where there is a mask applied to it.
Please find attached XLSForm for your reference.
Weng
Tags (1)
IsmaelChivite
Esri Notable Contributor
Thanks. I was able to reproduce this behavior. I will add to the backlog with low priority. (Hitting the delete button moves your cursor back to the beginning).
IsmaelChivite
