Map Scale When Searching in Geo Question
599
02-09-2023 08:25 AM
ZachBodenner
MVP Regular Contributor
I built a survey in 123 Connect to be published to our Enterprise 10.8.1 Portal. It contains a geotrace question, which enables the submitter to search a location based on address. Is it possible to adjust the zoom scale that results from this search?
Happy mapping,
- Zach
AdministratorWellington_Water
I would also like to be able to adjust the zoom scale upon searching for an address.  Enterprise Portal version 10.9.  I'd like it to select the address as well so I can see the result of my address search.
