Map Scale Lock ArcGIS Pro
5442
06-23-2022 07:40 AM
eyohannes
I'm trying to lock the scale at 1:807,794 so that I can navigate across my map to different Residencies of Virginia with the same zoom level.
Is there a way to lock this scale?
JohannesLindner
You can set a fixed scale for map frames in layoutsMap frame constraints—ArcGIS Pro | Documentation
For working in the actual map, you can utilize a custom scale:
´Then you can pan (and zoom)  to a differnet part of your map and select your scale from the scale list:
If you only want to see your custom scale, you can delete all other scales from the list...
Have a great day!
Johannes
eyohannes
This was very helpful. Thank you!
