Manually entering DMS coordinates
3019
11-03-2017 11:00 AM
EmilyBartee2
Is it possible to manually enter coordinates using the DMS format within the map?  The settings for the survey are set to DMS and the coordinates in the bottom left corner of the map display in DMS when viewing the map.  However, when you select them to manually change the coordinates, the format reverts back to DD.
Is this a bug or does Survey123 not yet support entering coordinates in DMS?  I'd appreciate any feedback, thanks!
Tags (3)
JamesTedrick
Esri Esteemed Contributor
Hi Emily,
This currently isn't possible; that being said, alternate coordinate format entry is an area we're actively developing and are working to support.
EmilyBartee2
Thank you for your reply, that's what I needed to know!
