Make un-selected choices from first multiple question disappeared in the second single choice question.
45
9 hours ago
Reuben
hi ArcGIS Survey 123 Users,
I am looking for an appropriate syntax I could use to hide unselected choices from a previous question (select multiple choice question) so that only, the selected choices appeared in the follow-up question?
Example:
Question 1: List the problems faced by the community (Select Multiple Choice Question)
A list of problems will be selected from the existing Excel sheet.
Question 2: What is the priority #1 Problems (Select Single Choice Question)
Only the selected problems in Question 1 should appear here (not the entire list)
Appreciate your comments
