Make survey ribbon full screen
1775
10-27-2022 08:25 AM
MonikaWheat88
there any way to make the survey ribbon wider or to remove the background image and have the survey be the only content when opening up? I know this typically can be done with html code but we don't have the ability to edit that info
basically only want to see the info in the red box.
IsmaelChivite
Esri Notable Contributor
At the very end of the survey URL add ?hide=theme,footer,navbar
For example:
https://survey123.arcgis.com/share/<YOURITEMID>?hide=theme,footer,navbar
More info here: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-web-form-url/ba-p/...
MonikaWheat88
This really helpful but there a way to make the survey ribbon the full width of the page? or is that just the design we are working with?
JenniferAcunto
In the blog Ismael linked:
Adjusting the width of the survey in the screen (width)
The width parameter sets the width, in pixels, of the survey in the screen. For example:
...?width=1500
Note that you would be extending it via pixels, so how much of the screen it takes up will vary depending upon the user's screen size.
- Jen
NikkiKuriata
Hi there! I've read through the blog, but I'm a bit confused as to where I go to actually add the parameters? I'd like to add
?width=1000
to my survey as it will only be viewed and used in browser. Is the parameter something I can edit within AGO or on the Survey123 site? A bit confused since I am new to S123. I'd like this to be the default URL for my survey.
Any guidance is appreciated!
