make image conditionally required
882
09-26-2025 10:58 AM
SarahRijneke
Hello,
It's been a while since I've had to configure or edit a Survey in the Survey123 web designer. I have an existing survey that needs to be modified. Is it possible to include a conditionally required image and note?
Use case: field workers are performing playground equipment inspections. Each page of the survey includes multiple singe select questions. I would like an image and note question to be required if any of the single select answers are "in need of repair." Is this possible?
DougBrowning
MVP Esteemed Contributor
Yes you can - the box for required has a drop down with yes but you can put any formula in there that evaluates to a true/false as well.  You will get the green mark of an error but it works.
You can also use relevant and just hide the field completely.
SarahRijneke
Can you elaborate further? I would like an image question to be required if chains is In Need of Repair but the drop down only gives me a count option.
DougBrowning
You want to set relevant on image and the note not a constraint.  I only use Connect so not sure on the web but look for relevant not a constraint.
