Hi Manish,
Thank for your reply. Since Web Designer it's not on par with Connector, do you know if this workflow will work without breaking the Web Designer form or losing data?
1- Create the survey using Web Designer,
2- Use the feature service created in (1) to create another survey with Connector,
3- Add new fields and the functionally in Connector that Web Designer lacks.
