Lost draw functionality after publishing survey
1087
07-26-2018 09:54 AM
JohnHuillery1
I'm attempting to publish a survey with inbox mode enabled with a field with the following parameters:
  • type=image
  • appearance=draw
I can draw on the images fine in Connect but when I publish the survey and load a survey from the desktop client or Survey123 app, it only shows the label.  Any ideas?
Tags (1)
by Anonymous User
Not applicable
Hi John,
Thanks for your post, we have identified with issue as a bug introduced in the 3.0 release, and will be working to fix it as soon as possible. I have added your comments and feedback to the issue and will keep you updated when we are ready to release the update to fix it.
Phil.
JohnHuillery1
Are there any work-arounds?
I'm using v 2.8.4 by the way.
by Anonymous User
Not applicable
Hi John,
There are currently no workarounds, although you can simply the delete the current image entry in the app (select the read trash can), and then select a new draw or annotate using the button, and it will apply the default image.
We are planning to release a hotfix for this issue soon.
Phil.
JohnHuillery1
Any progress on this?
