Location based variable in Survey123 Form
1144
02-07-2020 06:26 AM
DakotaDorn1
I am trying to create an online burn permit form for our Fire Department. I have everything figured out, except that they would like all submittals within the urban service area (polygon) to be rejected and prompted to not burn. Everything outside the urban service area (polygon) would be able to continue with the form. Is this possible in Survey123?
Dakota
JamesTedrick
Esri Esteemed Contributor
Hi Dakota,
This is most easily possible through the use of webhooks (or GeoEvent Server) to conduct the analysis and send a response or update the response after submittal.
