Linking dual maps in a single survey
747
01-10-2024 10:08 AM
HeathAnderson
Greetings All,
I am working on survey where I want the user to choose between a pre-existing route or the ability to select their own.  What is the best way of going about this?  I have attempted to create survey with two maps, one for pre-existing routes and one for sketching.  For the pre-existing routes I set the bind::esri:fieldType as "null" and the  body::esri:style to an existing MapID, then left the sketching map as default.  However, I am receiving and Error 500 code.  I understand that there should only be one feature per survey but thought that setting the fieldType as null was a work around.
Else do I create a picture picklist of the pre-existing routes and only one geometry sketch feature.  What's the community's thoughts.  @IsmaelChivite what are you thoughts on this? Thank you
Best,
Heath
