Limit the number of records to show from a table in a survey123 report.
1332
06-20-2023 12:12 PM
FrankDay
My report shows annual test results for different locations. Test results are stored in a relationship table. I want the report to only show the last 2 years' tests. I have attached a copy of the report after being created by Survey123 and a copy of the document used to create the form.
IsmaelChivite
Esri Notable Contributor
In your report template, try replacing
${#BACKFLOWTESTRESULTS}
with
${#BACKFLOWTESTRESULTS | where: "TESTDATE BETWEEN CURRENT_TIMESTAMP - 730 AND CURRENT_TIMESTAMP" | orderByFields:" TESTDATE DESC"}
More on this here: https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereportqueries.htm
IsmaelChivite
with
