Labeling repeats
1078
05-23-2019 01:26 PM
Nicole_Ueberschär
Hi folks,
I am looking for a way to somehow label repeats. In my survey I need to ask for (almost) each hour of the day for certain activities (in total 4 questions). Now I thought, I could create a repeat for each of these hours and put inside the questions - that should work to my clients' convenience. But I would like to put the time of that hour (e.g. 8-9am, 9-10am, 10-11am, etc.) on each repeat so it is easier to know for which hour they have to answer the questions.
Do you see a way how to do it? Or any other idea how I could create that kind of matrix?
Ismael Chivite‌ and James Tedrick‌, it is very annoying that the table-list appearance still does not work in the field app. I have 15 questions with the same answer schema under each other and it could save me so much space and it would also look so much better in a table look! 😞
Nicole_Ueberschär
I found a quick solution which is not yet perfect but should work for now:
I created a select_one field for the time with the names 1-20, and the labels 4am-5am, 5am-6am, etc. This field I defined to calculate "once(count(${counter}))". While counter is a hidden field (thanks James Tedrick‌ for that hint in another post) with the default value of 1. My time field I have now set to read only so the user cannot change the time slot.
The only thing I would like to change now is the availability of the drop down menu for the time. I have set appearance to minimal to just see the selected time slot but the drop down is still showing although it is read only... but that's more cosmetical...
Nicole_Ueberschär
